1 - 11 of 11 Posts
Too Cheap to paint!
Just got back from Limey69's secret Cobra workshop deep in the woods of Pennsy...
He helped me with the welding & Install of the sway bar
Too Cheap to paint!
Discussion Starter · #2 ·
As I am slowly updating and making my FFR a willing and quick club track car, while keeping it street legal, you all here have seem me do many updates.
Currently, the car is undergoing a major update, with slicks, wider rims, the front sway bar, brake ducts (where are the Cobra Earl?), an new motoper, and a few other tweaks, Cobrask8 is turning into one cabable rocket.
One month to the Glen, I plan on a heck of a school up there.
The VPM Kit is just as they advertise, complete, simple to install, and it does work!
Here's the kit:
Too Cheap to paint!
First off, up on jack stands, off with the spoiler & wheels, and LCVA front bolts for a test fit of the bracket:
Once it was good, we ground off the paint on the front of the 4" tubes...
and loosely mounted the sway bar to get the brackets in position:
Once all was straight & measured, welding time!
Too Cheap to paint!
Once the sparks stopped flying, cleaning & some heavy paint...
and everything was bolted up for final alignment & once the car was on the ground, everything tightened up. End links were set for no pre-load.
Drove it home on some twisty roads. I could only do so much with street tires, the real test will be on the track in a month.
But, from what I Can tell, with the bar still on the softest setting, the car does feel tighter, and plants the outside tire in a turn, and there seems to be lass body roll as well.
I'll wait for the track & pics to tell the final story, but wanted to put these up. Seems every time the VPM bar is noted on these forums, alot of people ask about it, so I figures I'd show everyone what's involved.
A BIG Thankyou to chris (Limey69) for his considerable welding talents.
chepsk8,
The next change you shoudl do is the rear bar and SAI mod. It will drive like a completely different car. My car handles unbelievable WITH street tires.
Maybe, if I get everything together I will see you at Watkins. Are you running HPDE NASA PDA? I was there in May.
Too Cheap to paint!
Running Pheonix CMR mid-August.
The car is an evolving process, one step at a time. This year's mods will be enough to re-adjust to!
My ultimate goal is to get the car very stable on the track, and kill off any of the inherent "nervousness", while still keeping it a friendly companion on the street.
I'll see how it runs at the Glen, and possiblyone more event this year.
I have heard much about the SAI mod, where can I get specific info? I am 3-linked out back, so that will remain as is.
Sr FFR builder
Originally posted by trevor:
SAI mod
What is that?
Also, not to hijack thread, but are both front and rear sway bars necessary or can you get along with just the front? I ask this because I need as much clearance in the back as possible for under the car exhaust and feel the sway bar would steal precious real estate needed for exhaust.
...unsafe at any speed
It is the "Steering Axis Inclination" mod. It was developed by D Borden and is sold by Whitby's. It is an optimization for the 17" wheel/tires combo's with SN95 spindles only. I've done the SAI mod, have VPM sway bars front and rear, w/Koni 30's all around, 275's up front and 315 drag radials out back, and the car is a go cart on rails :D . I run the front sway bar at max stiffness (as per VPM recommendations) and adjust the rear bar to balance under/oversteering.
Looks great, I have them and love them. FYI I had to grind/cut some off the end off the bar, it ground into the lip of my wheel.Not a big deal going forward, not good backing up.
I run full stiff front/ full soft rear w/irs.
Dan, do a search on the SAI, it's been covered alot. The rear bar mounts high and would not interfere with exhaust.Check out their website.
Dan, you could have photo-shop'ed in some more hair for me!
1 - 11 of 11 Posts
