JRCuz;5746474I finally finished the fuel line and the passenger side floor today said:How did you wind up routing your fuel line? I wound up needing to move mine after I got the motor in as the fuel pump was on the drivers side front of the motor. From what I can tell you are going with a similar setup to me and may have the same issue if you come up between the p/s f/b and the 4 inch frame rail. I wound up having to come forward with the fuel line and then going across the front 4 inch tube to the drivers side.
Not sure... At one time they were included. The 18's that came with my Anniversary Roadster didn't have them and I was told by FF they are no longer supplied. But then several have chimed in since and said they are included and were shipped with their wheels. Best to call and ask. They're standard TR413 rubber pull-through valve stems, so nothing special if you do need to get your own from your installer.My wheels arrived today, last of backordered items. A quick search looks like valve stems no longer come with the wheels, is this correct? No big deal if so, just checking. JR
