1 - 2 of 2 Posts
SOLD SOLD SOLD used Jesel KSS-516060 - Jesel Sportsman Series Shaft Rockers
Rocker Arm System, Sportsman, Shaft, Full-Roller, 1.6 Ratio, Aluminum, Ford, 289, 302, 351W, Kit
$550 plus shipping from 89148
call or text
(702) 423-3472
Stacy
Brand Jesel
Manufacturer's Part Number KSS-516060
Part Type Rocker Arms
Product Line Jesel Sportsman Series Shaft Rockers
Summit Racing Part Number JES-KSS-516060
Rocker Arm Mounting Style Shaft
Rocker Arm Ratio 1.6
Rocker Arm Style Full roller
Shims Included Yes
Rocker Arm Material Aluminum
Self-Aligning No
Rocker Arm Body Style Standard
Rocker Arm Finish Natural
Quantity Sold as a kit.
Notes These rocker arms fit AFR 165-225cc Outlaw small block Ford cylinder heads.
Since their release, Jesel Sportsman Series shaft rockers have proven themselves to be the ultimate replacements for inadequate stud rocker assemblies on OEM and aftermarket cylinder heads. If you are still spending aggravating hours adjusting your stud rockers, only to have to repeat the procedure the next weekend, then Jesel Sportsman Series shaft rockers are the solution for you. These 2024 aluminum bodied shaft rockers are able to easily handle today's aggressive springs and cam profiles. They are designed to withstand open spring pressures of up to 900 lbs., while maintaining precise valve lash settings. Both racers and engine builders have been rewarded with years of reliable, trouble-free service from their Sportsman Series rockers on countless applications, from daily drivers to bracket drag cars, various marine applications, and oval track dirt and asphalt racing. Jesel Sportsman Series rocker kits are designed to bolt on without any cylinder head modifications and, in most cases, still fit under a stock valve cover. The rocker geometry is preset and engineered using the common valve supplied with the particular cylinder head to provide a bolt-on-and-go installation.
1 - 2 of 2 Posts
