1 - 11 of 11 Posts
IIRC you need to flow about 850 CFM. Ask filter manufacturer flow capacity of the filter you are interested in.
I don’t know if there is any correlation between air filter flow and carb size but Ford Racing recommends a 750 CFM carb for that engine. I don’t know if that means anything or not.
Bill Lomenick
750cfm is just right for that engine unless you intend on full race. Make sure it's a QuickFuel. Good read here
Agree on carb size. Long time away from carbureted engines but it was all too common for people to over carb engines because bigger is always better.:)
Factory's generally covered carb size against unknown end usage by using a larger carb with vacuum secondary control that would open them on engine demand.
Not as sexy as a double pumper but effective on a street/track car when properly dialed in.
Certified Mad Scientist
The planned engine is a custom build using a Dart block. Have made no real decision on a carburetor, yet. The finished air box/filter assembly, Front Runner drive system, and full exhaust will be given to the builder. We'll talk about what I expect from the engine when I drop that stuff off and we'll choose a carburetor then. I don't want to have to redesign the air box if he tells me it doesn't flow enough. Just trying to make sure I get in under the 10% restriction level at max RPM. Hell, it might even get a vacuum secondaries carb if the torque curve is fat enough! I've tuned a few sweetheart small block chevys with mild-ish setups using vacuum secondaries, but nothing at this power level.
Eric
You will lose power with that filter, but more likely will loose more with the typical air filter tray and lid than the element itself.
Discussion Starter · #11 ·
OK, time to change the design plan. Looks like I'll need a big, round filter, and drop it as much as possible to get as much height as possible. Time to dust off the old fabrication skills again...
Eric
1 - 11 of 11 Posts
