Well, I know in the past there has been alot of discussion on how to wire the rear tail lights so that all the lights come on by using a trailer harness. Well, I am using the Painless harness and played around with it and did the following. I wired all 4 of the red tail light wires to the brown tail light wires of the harness. This causes all four dim tail lights to be on when headlights are on. I then wired the bottom green(brightest) tail wires to the respective turn signal/brake wire from the painless harness. I then used the painless third brake light wire to connect to the two upper green tail light wires. I have only done a little testing with this setup but it appears ok. I now have all 4 rear lights as running lights and all four go bright as brake lights with the bottom light on each side being a turn signal. Are there any problems with doing it this way? I will try to do further testing soon. I just suck at working on electronics that don't have a keyboard
. I don't want to burn anything up
Slowly but surely this thing is coming together. Tonight the hood and trunk go on and then the splash panels. This last bit of stuff takes longer than I thought.
