I installed my rear IRS spindles which are new and noticed that on both sides the lower mounts have a space that looks like should be shimmed. It looks like to much space to tighten and pull in with the bolts. The bolts are 14mm which makes it harder to fine shims.. Any thoughts?
I recommend you take a look at VPM (Vintage Performance) in the Advertisers section above. They offer Poly bushings for the bottom and top links of the IRS as well as other products. I used these on my Coupe and the benifit is you do not have to run Quad shocks to reduce wheel hop due to the deflection of the stock rubber bushings.
CB
