I have two aluminum IRS rear diffs w/ traction-loc.Both are 8.8.One has 3.07 ratio and the other is 3.27.These pumpkins have less than 36K on them and were swapped out under ford warranty about 18 years ago.I will offer a 30 day warranty if any bearings need to be replaced.I will not warranty ring and pinion set.If there is a problem,bring the diff back and I will replace any defective bearings at no charge.Want a different ratio installed?I would be happy to change it at a reasonable cost.These units are like new and are ready to install.Asking $750 each.
H/O Guy ,
!.whuy were the diffs exchanged under warranty?
2.where are you located?
3.does the price include shipping(they're heavy)
4. how do you plan to warranty them?
Paul
I know Frank I was going to make that my Item 5,but changed my mind for no apparent reason.
Paul
1. I don't know why they were replaced.
2. Location : Rhode Island.
3. I would assume the buyer pays shipping.I usually do when I purchase parts.
4. Simple, you give me the diff back,I fix it at no charge to you.Excluding ring and pinion replacement.
Why does it look like it’s been spray painted. 36k miles on both?😏
