I know I have seen people using the U-haul tail light converter to combine turn signal and brake lights. Has anyone used the Hoppy 48845(Hopkins manufacturing) switch from Autozone. It's very simple to wire up and I have tried two switches with no success. I even had an E.E. from work test it and it simply doesn't work as expected.
It has 4 wires in(left,right,brake,tail) and 3 out(left,right,tail). The tail simply runs straight through(unswitched). I can run 12Vs through any of the three other wires and I get nothing from the two on the output side???? Any ideas....I would say bad switch, but two in a row?
What does the U-haul switch run...I guess I'll try one of those next. BTW, Does Russ's turn signal switch assembly provide integrated signal action?
