My stock inner boot is torn and I'll need a new one to use on my Pro 5.0 shifter. The instructions show how to trim the boot so it fits over the stop ring. Does this work well? It looks like quite a stretch. Are there any other options?
[ November 02, 2006, 07:51 AM: Message edited by: Buckeye ]
Someone makes an inner boot for the 5.0 shifter, but I can't remember who it was. Maybe a search would turn something up.
I just found the boot. It is the one used on the Hurst billet/plus shifter. It will fit down over the ring on the pro 5.0 shifter.
Bill G
[ November 01, 2006, 10:39 PM: Message edited by: Bill G ]
Mike Forte supplied one with my T5Z and its a bit of a stretch but fits over the Pro 5.0 no problem
Forte told me he has used a CV joint boot for that so thats what I did. I cut it so it stuck up about a 1/4" above the trany tunnel alum. and then put the decorative boot over it. Should keep most of the dirt out.
Mancunian- did you trim the new boot or just stretch it over the ring?
Mike- did Forte's sell you the CV boot? What vehicle is it for?
Buckeye,
I just did the search, but you beat me to it. I used that cover and it is good fit.
Bill G
I made one out of the stock mustang one, with a tie wrap to hold the bottom to the shifter ring, but had to remove it because it was making the shifter pop out of gear occasionally. For what it's worth, I've never seen any trace of dirt, or water in the top of my Steeda Triax, even though I worried about it initially.
My T5Z came with a boot fitted and I can't tell if its a CV joint boot or not. It does have a thick rubber tab on one side at the edge that goes over the shifter,
