And let's have some really technical stuff in there too! Would also like to hear relationships with fuel rails, throttle bodies, MAFs, fuel pumps, etc.
Here is more info on injector sizes/color codes.
Flow PSI Resist Mfg. Part Color Application
1.76 (14) ?? 2.25 Bosch E3EE-BA Blue 1983 1.6L
1.76 (14) ?? 2.35 ND E4EE-AA Blue 1984 1.6L
1.76 (14) 30 16.20 ND E59E-AB Gray 1985-6 2.3L Truck, 5.0L SEFI
1.76 (14) 33 14.50 Bosch E67C-AB Gray 1986 2.9L, 3.0L
1.76 (14) 33 14.50 Bosch E67E-BB Gray 1986 5.0L SEFI
2.45 (19) 40 2.25 Bosch E6EE-AB White 1985-6 1.9L
2.45 (19) 32 16.20 ND E6TE-AB Gold 1986 5.0L HO SEFI
2.45 (19) 33 16.20 DKK E5TE-AB Gold 1985-6 5.0L Truck
2.45 (19) 33 14.50 Bosch E5TE-BB Gold 1986 5.8L Truck
3.00 (23) ?? 2.40 Bosch E4EX-AA Black 1984-5 1.6L Turbo
3.86 (30) 35-45 2.40 Bosch E3ZE-BA Green 1983 2.3L Turbo
3.86 (30) 35-45 2.35 DKK E4ZE-AA Green 1984 2.3L Turbo
4.41 (35) 35-45 2.35 DKK E5ZE-AB Gold 1985-6 2.3L Turbo
4.54 (37) 40 2.25 Bosch E3VE-A1A Green 1984-6 3.8L CFI
4.54 (37) 40 2.0 ND E3VE-A2A Green 1984-6 3.8L CFI
5.81 (46) 33 2.40 Bosch EOSE-A1A Blue 1980-3 5.0L CFI
5.81 (46) 33 2.00 ND EOSE-A2A Blue 1983-4 5.0L CFI
5.81 (46) 33 2.25 Bosch EOSE-A1A Blue 1984 5.0L CFI
6.60 (52) 32 2.25 Bosch E4ZE-CA Gray 1984-5 5.0L HO CFI
7.00 (56) 16 1.40 Bosch E43E-AC Blue 1985-6 2.3L HSC
8.00 (64) 16 1.40 Bosch E53E-AB Green 1985-6 2.3L HO HSC, 2.5L HSC
14 F1ZE-B4C Gray 1.9 - 3.8L
19 FOTE-D1A Yellow/Orange 4.6L SOHC
24 F2LE-B2A Lt. Blue 4.6L DOHC
25.3 F3DE-A2B Blue/Green 3.0L Flex Fuel
30 F1SE-E1A Red 3.8L SC
The flow rate is gm/sec and lb/hr in parenthesis. The resistance is obvious.
The manufacturer is next, I think ND is Nippondeso (sp?), I can't place DKK.
The part number is constructed as follows. All injectors carry a basic part
number 9F593, which is prefixed with a production release, and followed by
a revision/application code. For example E3EE-BA from the table will be
E3EE-9F593-BA to your local dealer. The tops of the injectors are color
coded, as a quick check to the technician to make sure an engine contains the
"same" injectors. I included some sample applications which may help the
dealer if you are buying new, or yourself if scrounging in a junk yard.
I don't know what was used for the density of the fuel. I typically use
0.79 (rounded up to 0.8 for "quickie" calculations), and I have seen people
use 0.775 for "racing" fuel.
There are two different types of injectors:
High Impedence and Low Impedence.
They are not interchangeable.
The Ford factory EEC systems use the High Impedence injectors.
http://www.msdignition.com/ Click on the blue button that says fuel systems.
You have to have an aftermarket injector driver, a modified EEC, or an aftermarket computer to run low impedence injectors.
Also, rules for supercharged cars are different than NA cars for injector sizing due to fuel consumption.
Some other links:
http://www.rceng.com/index.htm
http://www.fuelsystems.biz/
http://www.mrgasket.com (Click on the Accel link)
