Can the inertia switch hander the amperage of my Edelbrick electric fuel pump? Or should I run it all the way to up to disconnect the fuel-pump relay?
As allway, Thank You!
Rich
I think it depends on the switch. As I recall early FOX the inertia switch controlled the relay, later ones were in the path to the pump.
Sorry but I don't have dates, but mine - an 89 donor - is on the relay ckt.
All the Fox Inertia switches that I had would not handle the current of 255 lph intank pump. Some will run the pump but pop after a while. Either use it to ground the input signal for FP relay or run another relay inline in the back.
mk 1.5 original
The 94/95 switch is after the relay and before to the pump.
I run a 255l and a t rex through the 95’ switch. 2 years and 6000 mile no problems.
Chris
mk 1.5 original
oops forgot. its the 255l pump and the t rex relay that is fed by the switch.
chris
Sounds like I should just trigger the relay. I do like the idea of switching the ground for the relay...interisting idea. Thanks guys!
Rich
