I cannot get my car to turn over. When I turn the key to the on position, the fuel pump turns on and the gauges all work. When I turn the key to start, I get a click at the starter solenoid but nothing else. The battery is new and I have checked all grounds. Does anyone have a diagram showing the wiring from the ingnition switch to the solenoid and beyond?
Ok, 2 solenoids, 4 trips to the auto parts store, a new ignition switch, and a few grey hairs later.....a 99 cent wire brush fixed the problem. After getting very frustrated, I went around to each grounding point and cleaned the ground contacts. Each time I cleaned one of the grounds, I would try and start it again. On the last contact on the engine by the water pump, I cleaned it up, tried to start it and VROOOOM! I am now a firm believer in CHECK THOSE GROUNDS! Thanks everyone for your help.
[ October 17, 2002, 08:01 PM: Message edited by: Fang Bit ]
