1 - 2 of 2 Posts
I need help. I don't have much of a clue when it comes to wiring. I put a 92' 302 in a 66' Mustang and am using the 85' distributor set up. I have the MSD Motorsport module which plugs into the Dist. but I don't know what to do next as far as wiring it to a source so I can start the engine. What do I do now? It looks like the coil wire would plug into the existing wire lead. But can the power wires be tied into the solenoid or do I need the ignition switch to wire. As much detail as possible in your explanation. Thanks in advance. Tim
Tim,
I dont have any knowledge on that setup.
I apologise and recommend you try the general forum for assistance.
Do you have a wiring diagram for the MSD?
Ed
FFR1997K
1 - 2 of 2 Posts
