Hey all.
I have some concerns about the FFR tubular A-arms and the front coil-overs. I assembled the front suspension today, and everything looked good until I went to install the coil-overs. The first picture shows where the lower spring perch on the coil-over hits part of the FFR tubular A-arm (red circle). This seems to be significantly restricting the travel range of the front suspension. The position of the a-arms in these pictures is as low as that spring perch will allow them to go. Does this look right to those of you who have installed FFR's tubular A-arms? I haven't been able to find a really good picture to compare mine to. Should the front suspension be able to extend lower than where mine is in these pictures, or am I getting all worried over nothing? Mainly, I don't like how the whole front suspension binds on that spring perch when it's fully extended. Also, what is a good rough height for the coil-overs to be adjusted to during assembly? I don't have any wheels yet.
Thanks a lot!
Thanks a lot!
