1 - 2 of 2 Posts
Delivered
I dont have a used head gasket to clay my engine with, any ideas on spacing the head to check?
I'm using JE flat top pistons, victor jr heads, 35-426-8 comp cam, and 1.6 rockers. Been told it will clear no problem since the pistons are designed for 650ish lift but i want to make sure.
Pro FFR Builder and Moderator
don't use a gasket at all. Set the head with a couple of bolts. Add .038" to the clearance you have measured with the clay and that will be the actual measurement.
1 - 2 of 2 Posts
