1 - 12 of 12 Posts
Hello everyone, I just started building a week ago and have encountered my first major problem. I have the new style steering shaft and I am unable to get it to slide all the way onto the splined steering rack input shaft, anyone have any ideas?
Front end progress so far...
Suss,
Looks like you coming along on the suspension. I don't have the same setup with my MK111.
Good luck,
Ron
Don't you have to jack up (put a load on) the LCR's before torquing the bolts?
Incorrect and irrelevant. His question was on the steering shaft spline.
Looks like the set screw hasn't been backed off enough. Also, I would wire brush the splined end on the rack and put a little oil on before trying to reassemble.
are the steering rack and steering shaft the same (i.e., manual to manual?) I believe FFR sends a power steering shaft by default, unless you specify otherwise.
I am using power steering and have already wirebrushed the spline, is it supposed to sit all the way down? anyone else have this setup and some pictures?
To reiterate, are you sure the set screw is backed out far enough? It doesn't appear so in the picture.
I would jingle FFR in the morning. I believe FFR has a manual or power steering shaft. Looks like you may be all the way down on the spline, let us know how you make out
1 - 12 of 12 Posts
