Has anyone that is using the I Squared 1 + 1 system used a 3G alternator?
I have been tentatively planning wiring around the I Squared system and was planning to use a 3G alternator but cannot find any wiring diagrams for anything but a 1 wire alt on the I Squared site.
Anyone?
TIA,
Thanks Don, I did not see the 3G near the alternator in the drawings before.
It looks like all you need is the battery + and ground. Is that right? I thought the 3G used a special plug and harness with 2 or 3 other wires besides battery +. Do I not need anything else hooked up to it for it to function?
Tim,
I found this on the site when I wired up my 3G alt and I-Squared system. I found a replacement alt plug at my local auto parts shop. Plugged straight in.
3G Wiring Diagram
Hope this helps,
Thanks Steve,
Where did you run the red ignition wire? To the switch or the ign termianal on the power controller?
thanks again,
Hi Tim,
I ran the red wire to a power distribution block which was powered from the ignition circuit on the power controller. No power circuits go to the switches on the I-Squared setup. I converted to an electronic speedo and now I can completely detatch my entire dash with only two connectors - this includes all switches and guages. Really impressed with the I-Squared setup.
Cheers,
