I would like to put either vacuum or hydro boost on my mk3. I have the master cylinder already and was hoping to not have to replace it.
Any ideas?
As long as you already have the master cylinder that was used on the donor mustang. Just get the mustang booster. If useing a jeep m/c not sure that would work. Rebuild mustang m/c is about 30 dollars if needed.
Do a quick search on power brakes. Plenty of pics and discussion on here.
You'll need the unmodified brake pedal,booster,frame mod. Frame mod now comes in a bolt on section since section of 3/4" frame needs to be droped by foot box. Also need to relocate lowwer steering bearing to inside firewall instead of outside. Couple holes need to be enlarged where the present m/c bolts. Worth the effort.
proud builder&owner
If you already have power steering, go with the hydroboost,no chassis modification.
proud builder&owner
Tell you what I did, ordered a hydrobooster from Summit with M/C included(450$), installation is really simple,just had to custom made the high pressure hoses, you can always use donor ones,and connect power steering pump to h/b, then from h/b to steering rack,and connect two low press. returns to the p.s.pump,works great and even helps reducing a litlle the p.s excesive power. The only "issue" is: the complete system is a litlle long and interferes with the inside wheel aluminum panel,I cut a small hole and covered with a riveted small box(forum recomendation). Better this than cutting the frame for a booster.
Fernando.
I dimpeled the "elephant ear" using a lead shot bag and rounded plastic mallot. It made a nice smooth "blister" to clear the M/C with Hydroboost.
