Does anyone with a FF using a big block utilize a hydraulic throwout bearing? If so, what peddle assembly do you use? That seems to be the biggest hurdle. Anyone with advise or help on this matter is greatly appreciated. Thanks BrianC
Originally posted by Gatorac:
Brian,
Do you have to use the hydralic throw out bearing? Please explain as I am on my way with a big block build.
Here are some places to check for pedals.
http://www.wilwood.com/products.asp
http://www.tiltonracing.com/
You can get most of the Wilwood stuff at Summit. Just do a search under "manufactures part number".
