How do I wire the 3 position switch for the turn signals. On the donor stalk the connector has 5 connections. I think one is hot , and the other 4( 2wire ) connectors are for the signals. The harness is from a 87-89 donor.
Thanks for any info.
Muck,
Do you have a fax number?
I'll fax over the schematic.
It might make it easier for you to understand...
Hot wire goes to center terminal of 3 position switch.
The other wire pairs connect to the outside terminals.
use a multimeter to verify which pins have continuity when switch is in left or right position.
Ed
FFR1997K
