1 - 3 of 3 Posts
Am I going to have to pull the tranny - again? I assume the seal just presses in but I don't know if I will have to get it out in the open.
Mojo,
If the seal is leaking: I had the driveshaft that was causing the leak. Old (donor) yoke had worn and the new seal in my Tremec allowed some seapage (occasional drop on the garage floor).
Just a thought.
Rob
No need to pull tranny. Pry out the old seal and tap in the new one,after removeing drive shaft. Treat it like you would any seal install. Use the correct diameter seal driver(socket if needed) and don't disturt the metal shell of seal. Small bit of lube on seal before reinstalling drive shaft.
Check yoke for groove or rust. Two most commoon cause's of seal failure.
1 - 3 of 3 Posts
