· Senior Charter Member
The wrecker dropped off my 1992 5.0 automatic donor car yesterday. The problem is I don't have a set of keys to it so I would like to know how to fire it up so I can hear it run before I tear it apart.
Cody
p.s. If you know anyone that is looking for 14" deep dish wire rims for a 5.0 I have a set forsale.
· FFCobra Fanatic
Slide hammer to pull the tumbler out and turn with your finger....or a big flat bladed screwdriver and a big crescent wrench to turn it and shear the tumblers off. It's not like you want to save it.
· FFCobra Craftsman
Another way to do it is to remove the covering from the steering columm, then unplug the harness from the switch. Get a couple jumper wires. Find what slot is hot, then jump from it to the other slots until you find the slots the power the starter and computer (you'll hear the fuel pump). Run one jumper from hot to the computer slot, then touch the other to the starter slot until it fires. It's alot easier than it sounds.
Thanks Guys! I thought I good probably just force it with a big screwdriver and a hammer
I am off to tear up some stuff
