I think I have the problem....
Car goes over a bump and there is a quick grinding noise and you can really feel it if your hand is on the shifter lever. I have altrady checked for tire/body contact.
Heres what I have:
Stock MKII
8.8 rear
T5 tranny
Carrera shocks with overiders
4 link
upper links were are in the middle mounting holes.
Dennis
Dennis,
I don't know if this is your problem, but I had some contact between the driveshaft and the E-Brake hardware. I made a little guide for the cables and fixed it.
Carl
Thanks carl, But think it,s more that.
Thnks
Dennis
Sounds like you have a drive shaft binding problem.
What is the pinion angle set at now?
Do you have adjustable upper control arms so angle can be changed there?
Ideally you want 1-2* down if measured at the rear.
BLUE.II
Driveshaft bind is caused when the universal joint bottoms itself in the clearance cavities (tough to explain).
I did 2 things to eliminate it, after you verify the pinion angle:
1) Raised the rear of the tranny (at the mount) 1/2 inch using washers.
2) Took a look at the universal joint and spotted where the bearing housings were hitting. I then took a stone wheel on a dremel and made a little more clearance. (I figure that the castings weren't perfect)
There should be a lot of help if you do a search on driveshaft bind.
Hope this helps
A stock MKII with a T5 shouldn't have bad bind. What's your ride height set at? Try raising it 1/2" or so.
The spacer is mandatory with a Tremec, however, you can try it. I'd rather see you use one solid spacer that's the full size of the perch.
Washers concentrate the load in a small area around each bolt, plus a "stack" of washers is subject to corrosion between the washers. Much better to have one solid chunk.
d
I have had this problem as well 4 1/2" ride hieght is min. from the bottom of the round frame tube to the ground. Adjust this first then move on to the other things suggested.
Gregg
SInce it's grinding as the axle comes up you have two options 1- raise the trans by raising the whole car (probably not what you want to do) 2- raise the trans itself. While I agree w/ Donald that washers are not the best solution, they are a cheap easy experiment.You may also need longer bolts depending how much you need to raise the trans.After you get the height right decide if you want to get a solid spacer or not.
my front u-joint bearing cups were hitting on the inside of the yoke, I talked to the driveshaft man, he said it would be okay to grind some clearence in this area, and it shouldn't effect the balance since it's so short anyway, and I also adjusted the rear coilovers up 1 turn, haven't had it happen since, good luck.
chas
