1 - 14 of 14 Posts
Official OLD GUY
Eddie,
I wouldn't shrink-wrap it at all . . . this thing gets really hot and should be mounted where it will get fresh cold air as much as possible. Away from any other wiring or stuff you don't want melted.
Doc
Eddie like Doc said the resistor does get hot. Most cars had them factory mounted on the firewall clear of everything else. Remember the entire time car is running the resistor is working so it will be warm-hot since it's reducing the voltage and turning it to heat.
Eddie, you dont have to use that one. they make one that is a wire and it can run with the other wires. I bought one but didnt use it because my wiring harness came with one. 2000 miles and no problems yet.
Dusty
yes, the wiring instructions for my Mallory did have an alternate wiring diagram that using "OEM Primary (Loom) Resistance wire."
the diagram is the same, but i am not sure what that meant.
can this be mounted on a little bracket on the intake manifold, behind the distributor, under my oval air cleaner?
if i mount it on the firewall, is it a problem if i run wires all the way back there?
Eddie, are you sure your coil doesn't have the resistor built in?
the coil i have does. seems to me you have to ask for a coil without the resistor built in anymore.
you should check since you've been running without an external ballast resistor to this point.
Good Luck!
The resistance wire was used on GM cars till they went to electronic ignition. Might be an option,but check as I thought it needed to be a certain lenght if used. You can mount the resister other then on firewall,it does'nt have to go there. Some put them on the front of the engine,on side of coil bracket,just some where it won't do damage and can get some cooling air usually from the rad. fan. Main point is not to cover or tuck it away where it may heat or damage other wireing.
Discussion Starter · #10 ·
STOP THE PRESS
according to the MrGasket.com Mallory ignition coil catalog
29219 does NOT require a ballast resistor!
i am good to go - thanks guys, this means i'll be able to fire it up tonight... if Cannonball Cobra can come over and help me...
Good luck Eddie, I want to hear nothing but how great it's running.
Go Fast
Discussion Starter · #12 ·
should be tonight, Cannonball Cobra is coming over.... will advise with a brand new post
I mounted mine under my oval air cleaner, out of sight.
Bill, you missed the last memo. Eddie doesn't need a ballast resistor..never did.
1 - 14 of 14 Posts
