How much Urethane base coat paint l need for to put on mk3 no stripes British racing green with metal flake
and much Urethane Clear l need for to put it's to cold right now and l'm looking right now for a 60 gallon air compressor but the price is $1,300.00 that is nuts
l have a to small compressor its only 13 gallon and a LPLV air gun 1.3 and a HPVL gun 1.4
1 gallon of pigment plus reducer which with most paint lines will be a gallon making 2 gallons of sprayable material. You’ll have a few ounces left over. Clear is about the same; some mix 2:1 clear to catalyst, others are 2 clear to 1 hardener plus 1 reducer. Long story short you’re going to want 1 gallon of clear product plus whatever it mixes with.
Discussion Starter #3
JKleiner Thank you for your help will 30 gallon air compressor with LVLP spray gun be OK
30 gallon not going to be enough, get a 60. I used a 30 to prime but I came out really rough, upgraded to a 60 gallon and it’s just better all around.
