I don't know what year it was put on, but the steel lines that run over the intake manifold
for the heater hoses has a small nipple on it I would think for supplying coolant to the EGR.
I put a vacuum cap on it since I don't need the EGR option, How did you who also had this cap it off? mine has popped 2 times. I am trying to avoid having to remove and braze it shut thanks
section 8
replace with rubber heater hoses , or braided Bob
BLUE.II
On mine (if it is possible for you)
If it is the small coolant hose. Just replace the two pieces with one un-cut piece and by-pass the throttle body spacer. Let the coolant go out and around.
No problems.
Cheers
dhungerf Where would it reenter the system? I have a GT-40 intake
BLUE.II
Steve: I have the same intake.
The back passenger side you have a threaded hole. I put a threaded barbed nipple there and that's the return. You can see it in the picture, it has the teflon tape on the thread.
[/IMG]
Cheers
The '93 Cobra Mustang actually had a different part number coolant tube assembly without the hose nipple on it since the EGR was integral to that upper intake and didn't use a coolant passage for cooling.
I believe that part is obsolete now but you might find one on eBay or elsewhere. Barring that your option is to route it to a lower intake coolant port via 3/8-inch hose, or braze the nipple shut...
HTH...
1 Rubber tube, 1 bolt & 2 hose clamps. Not pretty but it works. I always meant to replace it with something a bit nicer but I guess it never bothered Me enough to do it.
I opted for the machine screw with epoxy and then a coating of epoxy over the whole nipple then some gloss black. can't even see it now
