I have the FFR hood hinge kit. I mounted the frame to the hood. Did anyone cover this with fiberglass. It doesnt not look that nice - see picture below.
Mine was coated in fiberglass and painted. Not by me though. It started cracking where the two bumps are on the bracket. When you open the hood it will flex the bracket and cause it to crack. I dont know if i would recomend it.
My body guy cut a sheet of black rubber foam insulation to fit nicely and painted a coiled cobra on it. Looks great, plus protects the paint from the engine heat.
mine was finished and painted the same color as the body and the frame was chromed, truly nice. Ford Royal Blue and Chrome go well together. Pictures in my site
I bonded mine on with West System Epoxy. Then I covered the whole underside with a couple of coats and sanded. When I painted the underside, I mixed some flatner into the paint. That way I got a respectable finish that matches the body color and is washable, but without spending more time than I wanted to spend on that area.
Has anybody tried putting a sheet of aluminum on the inside of the hood? I was thinking about doing it so that I could cut a hole in the aluminum that would fit around the air cleaner. Figured I could build a small tray under the air cleaner with some foam to seal it to the aluminum inner hood so that the engine only breathes through the scoop. Has anyone tried something like this?
I guess the hoop part of the hinge stiffens the hood when you lift it using one of the latch handles. The hood weighs 40-50 lbs. now, it seems a little ridiculous.
how do I mount the hinge assemlby to the frame. I have two plates for the hood pins that oviously have to go. It looks like a mounting plate was added to each side of the frame????
I don't have any pics, but sand it, coat with Epoxy and let harden, sand it again, coat with epoxy and let harden, repeat as necessary and spend some time at it. For final work, I used a glass filled body filler. It's not perfect, but it's smooth and it looks pretty nice. I painted mine body color.
