I just installed by circuit breaker across my battery disconnect switch. I left the car with the switch off with the breaker on. Got into the car and battery dead. Something in the gray/yellow wire circuit is drawing 2 1/2 - 3 amps and killing the battery. To solve the problem, I moved the G/Y wire to the switched side of the ignition switch. I guess that means that I no longer keep power to the computer. Is that going to cause me problems? What could be drawing 3 amps with everything off? I unplugged the couputer and still had the current drain. Any suggestions?
Tom
Tom
