Looking to use aftermarket horns (Hella). Looks as though the horns come with a relay.
I'm using the donor harness and stock relay. Is the OEM relay up to the task??? Don't know how much current the stock horns take. The Hella's run around 6 amps.
I am sure someone will chime in with the answer, but the stock relay should have a rating on it somewhere. Additionally, I think the stock fuse block had a horn fuse, look at what that is rated at.
Thanks. Good tips. I'll check the fuse rating. The relay is behind the dash so not easily reached.
Fuse for lighter and horn is 20 amps. I think I'm good to go. If anybody has the stock wiring and the Hella horns, I'd like to hear that all things are good with the stock relay.
