Hello,
We are running a vac. booster power brake set-up. There is a hissing (vac. leak?) on the inside of the car. The brakes drag slightly when warm but not if the motor is shut off. My question... is there normaly a slight hissing when you depress the brakes a tiny bit with the motor running? If I pull back on the brake with my foot, the hissing decreases by a bit and the brake drag decreases a bit as well. Is there an easy way to adjust the length of the brake rod without taking the booster off (big job with the body on)? Has anyone heard of a booster going bad?
