Hi from the UK.
I'm Marty. I've joined to source information on building my 1994 351W block.
I'm building a AK or Dax 427 cobra and would like to get my standard bore 351W up to stroker 427.
Just don't know if it's a good idea as I won't be strip racing or anything. Just general driving and a good blast when the roads are quiet.
To be honest reliability is my main goal.
I assume I'm sounding stupid?
Anyway please to meet you all.
I'm off to scour through the search function.
Marty
Super Moderator
Greetings Marty and welcome aboard from across the pond. Stretching a Ford 351W block to 427 cu. in. (7 liters) is possible. A stroker kit uses a lengthy 4.170" stroke to yield 427 cubic inches. As expected, because of this stroke, this motor will be very bottom-end heavy and is best suited for applications such as street cars, tow rigs, and trucks where RPMs will be somewhat limited. If you want a higher reviving engine It takes an aftermarket block like Dart .
Super Moderator
The 351 should be plenty of motor for spirited fun driving, or just out cruising. Save yourself the cost of building a stroker, for the expensive UK petrol, so you can drive more often..;)
What part of the UK are you in?
