I have an anonying hesitation.It happens in 2nd,3rd,and 4th gear...If I am between 2000 to 3000 RPM and mat the go pedal there is a split second puase before it wants to do anything then it takes off as normal.If I roll into the throttle it will respond fine.Here's the combo 5.0 EFI,X cam,AFR 165 Heads,1.6 roller rockers,Cobra intake,70MM TB,24 lb injectors,24lb calibrated 73MM MAF,10 dgrees inital timing,but using a programmable computer to map the curve,.995 TPS voltage,40 PSI fuel pressure,new fuel filter,155 Walbro pump.Any ideas.
[ October 16, 2002, 06:06 PM: Message edited by: Smitty ]
