1 - 1 of 1 Posts
Got a MK3 complete kit and finally got around to filling and bleeding the brakes. After fixings a few leaks and having to reflare one line, the bleeding was going pretty good but for some reason I was not getting any fluid out of the RR bleeder. Took the bleeder out....nothing. took the banjo bolt out..clean and clear; broke the fitting loose just ahead of the ss flex line ...bingo..fluid. Upon closer inspection we found that there was no hole in the end of the ss flex line where the banjo bolt goes in. Who thinks to look for the hole there? You just sort of assume its there. Oh well FF is sending me out a new one. Said that's the first time they heard of that. So...if you haven't already installed yours inspect them first. If they are already installed and your can get fluid out of one of the bleeders...that may be your problem.
Paul
1 - 1 of 1 Posts
