These parts are from box 1d (primary chasis components)
I have everything except the following parts:
1) 1 1'' Flange bearing
2) 1 pillow block, 3/4'' ID
These parts were in 2 bags, in box 11072 (steering bearings/hardware)
There are 6 pieces (3 per bag) and i have no clue what I'm looking at? What are these pieces?
A - from box 1
B - from box 2 (taped to box 1)
C - all in the same shot
Box 1 Pic 1 is the 1" Flange, mounts on the o/s footbox/steel firewall.
Box 2 Pic 2 is the pillow block, mounts on the 2" X 3" cockpit tube. It adjusts the height/angle of the steering column.
PS: If you look at Cobrabhoy's recent post on side pipes, he's got a great shot of the flange bearing.
Troy
EFNFAST look at my post re sidepipes youll see the bearing installed
jimmy O
Troy
Awesome, thanks
The Greek
Here is a post to help a guy with the setup.
Note some of these parts are for 94 rack but the parts you are looking at for all donors.
Also note: I have installed the flange bearing on the inside so the brake booster clears.
http://www.ffcars.com/cgi-bin/ultimatebb.cgi/ubb/get_topic/f/1/t/091534/p/1.html?
on my first picture you see what you show in your second picture
on my second picture you see what you show in your first picture although not very clear because it is installed.
If you need more pix let me know.
