i have to pass emmisions and not sure what is needed and what is not.
1) in prior searches i have found that the egr valve does nothing for emmisions. is this true
2) is the vapor canister needed
3) my plan is to run cats. with the smog pump blowing into all the time and cap off the heads. is this correct with the factory five cats
4) i have a supercharger that is 50 state approved for emmisions. i would like to put 30lb injectors in the car. will the bigger injectors after the emmision test
