Cobra Nutcase
Ok, i'm using the donor harness, pod, etc. Well I tossed the dimmer switch a long time ago. Can't I just bypass where the dimmer switch should be? I mean can't I just take two of the wires going into that plug or not?
I have a couple of dimmers pay postage and ones yours.
PM me if your interested
My second hand MKII has no donor illum.When you get that switch and plug it into the harness can you take a pic and repost.Hardest part for me will be figureing out which of the many unused harness ends the switch goes to.Thanks
Simple solution:
Get the Autometers!
Cobra Nutcase
Discussion Starter #6
I'll try and take some pics when I get it done.
I thought about the autometers, but I couldn't see forking out $450 and then have the needles fall off. Instead I spent that $450 on a set of coil-overs for the rear. Limited budget.
