I cut off the stock pedals, cut off half of the AC pedal mount stud, then side bolted the AC pedals to the Mustang pedal arms. There are some pics of the way I did my pedals at
pedals if you'd like to see. I don't know if this is the best way, but it was easy and seems to work well. I was able to bolt the brake pedal a little further away from the accelerator pedal using this method, for more foot room between the two pedals. One pic compares the size of the stock pedal pad vs. the AC pedal; turns out the AC pedal isn't really any narrower than the stock one, but it's longer so I'm hoping it'll fit my fat feet better. Oh, if you use soapy water the grommets go on pretty easy. Good luck.
[ July 30, 2002, 09:51 AM: Message edited by: John Phillips ]
