where do the following wires go,they come from the dash harness(1993),i am using 1 signal led
the stock headlight switch and a toggle for the turn signals,any help would be a big help...vinny
1)wht/blu (right turn indicator)
2)grn/wht (left turn indicator)
3)org/blu (right rear turn signal)
4)grn/org (left rear turn signal)
5)wht/blu (right front park and turn)
6)grn/wht (left front park and turn)
7)grn/red (batt indicator)
8)blk/blu and pnk/grn (warning lamp feed)
9)gry/wht (high beam indicator)
10)org/yel(turn sig flasher feed)
Vinny
You have them listed where they go!!
White and blue & orange and blue go to the right side of the 3 position toggle on-off-on that your using for your turn signal switch. (the right side as it comes thru the dash)
The green and orange & the green and white goes to the left side of the toggle.
The orange and yellow should be the feed for the switch.
The gray and white is for the blue high beam light in the dash
7 and 8 I don't use
And for the dash turn signal indicator use the 3 prong flasher that FFR gives you with the kit split the plug in half put on side on term 1 the other on term 3 and the feed wire to the dash lite on number 2
#1 I _ I #3
#2
hope this helps
thanks mike it does help,i had some conflicting info from some wiring diagrams,old posts and scetches of other cobras and since i am using multi pin plugs i wanted to make sure i did it right the first time,thanks again.....vinny
but i thought the right and left turn signal indicator wires(wht/blu and grn/wht) went to the green led with the use of diodes on them?,if i send the third terminal of the flasher to the green led where do the two wires go??,i already have the mustang factory flasher terminal split in half and attached to the supplied flasher,thanks.......vinny
· FFCobra Craftsman
Vinny,
I believe the diodes are for us non-donor folks using painless system. I had to put them in to allow seperation from left and rights. I believe your harness from the mustang has systems in it that takes care of this.. I remember someone talking about the light bulbs or something funny like that..
thanks guys,and Joe i know what you mean (in your other post) about the color choice being the hardest part,my choices are similar to yours with a lexus blue also in the mix,do a search for it,sweet....vinny
