Status
Not open for further replies.
I just got the engine in today but the trans mounting is about 1/2" too short. I changed from a stock T5 to a T5Z but I don't think that should have made a difference. Should I take a piece of steel plate and make a spacer?
Thanks Guys,
I had the hard mounts on the engine reversed. Lifted the engine and swapped engine mounts side to side. Voila everything fits.
Ben
[ August 10, 2002, 07:18 PM: Message edited by: n559br ]
I don't have enough information to be sure, but if I had to guess the motor mounts are not correct, possibly reversed?. We just did a mark II and the holes lined right up with a T5Z. Energy suspension mounts and no trouble. Hope this helps. Cheers Richard.
Richard,
I thought the same thing at first but they look right. If I moved the hard mounts the engine would move further forward. Do you know the correct distance between the motor mounts and the tranny mount?
Ben
I have a t5z and mark 2 it fit fine with no mods. I used convertible mounts. This dosnt help I know..
Status
