Hi! to All
Don't know if this is the right place to place this add ,new to the site ,just purchased a FINISHED 2005 Roadster MK III having a problem with the Brake & Clutch & Gas pedals being to close to each other I was told that there is a tool that you can clamp on the pedal arm and bend them to adjust them away from each other Your Help would be greatly appreciated
Danny K.
If you do a search on "Pedal Bender" you will find an bunch of info on the subject as well as some of the members that you may be able to borrow one from. I think there are a few in circulation. Regards Scott
I'll take it, but seeing this is your first post 7bbr, might you have a reference on the forum?
Ddmrk
7bbr is looking for 90 on that pedal bender and is in New Jersey, as are you.
You might as well grab it then ill buy it off you for what you have in it once you're finished with it.
Vic
