FFR #2084K is getting a new body this summer, and I decided to go with the rectangular tail lights. The cut outs our done, and the paint is on. NOW I notice that the new rectangular tail lights have no reflector behind the bulb. For that matter, there is nothing behind the bulb at all to keep dirt off the bulb and the inside of the lense. I looked at the Finishline site and verified that their picture of the rectangular tail light looks exactly like mine.
This can't be right. Something is missing.
Anybody out there solved this mystery already?
I made a plate out or 1/4" aluminum to no only seal the back but to be able to use two bulbs per light. I seperated the upper and lower portions of the lense with reflective tape and now have seperate turn and brake light bulbs.
I can tell you that at Spring Fling there was many close calls because of these tail lamps! The retangular brake and tail lamps are very dim. We run with a couple of Superformance cars and you need to be very careful if they are in front of you.
Jeff Hamilton
Hey Wade, I had the same problem, so I built small rectangular boxes out of some scrap .040" aluminum sheet. Just made3 them large enough to fit over the back of the light and left 2 tabs on the ends that have holes for the mounting studs to hold them on. Now the bulbs are protected and the taillights are really bright and noticable. Hope this helps, Your Friend BenC
