1 - 2 of 2 Posts
I will be installing the FFR heater and windshield wipers. Is the FFR suggested location good? I don't want to install the heater and later have a problem with wiper motor.
As allways thanks to all!
Rich
The manual states to install the heater first, then the wiper motor next to it. I would install the heater first, bearing in mind the Mk III dash brace might interfere, so measure and check your template for the heater before cutting your firewall.
Once the heater box is bolted up you can easily mark your two mounting holes for the wiper motor clamp to the outside of the heater box...
HTH...
1 - 2 of 2 Posts
