I am running a heater and need to know where I can get a fitting for the manifold that will allow me to run the heater hose and temp sensor in the front of the manifold on the passenger side?
Mike O.
FFCobra Captain
YOu should be able to go to the autoparts store or almost any hardware store and get some brass fittings.
You can find a t fitting with a male end to go into the manifold and the 2 female ends. You can put the temp sensor in one end and a threaded hose fitting for the heater line.
Hi Mike,
If you can't find one at your local store, I got mine from Breeze. I believe it's part# 70540. It's called a ECT sensor elbow kit for 5/8" heater hose. Breeze uses it for something different, but the fitting works great for your use.
That part # 70540 will not work with the Mass Flo manifold. I found out the hard way.
Mike O.
I have it on my mass-flo manifold. Is yours hitting the distributor or something else?
I drilled and tapped the boss on the thermostat housing for the temp sensor.
