Big Boy
Wayne thank you I will look into those options. I am located in Suwanee Georgia.
My headlights are very dull as I found out last night. What options are out there for a simple upgrade? The ones currently on are the basic 7inch round glass lights.
One thing is to use a good relay system that wires the lights right to the alt and uses the switch to trigger the relay. Read this:
Wiring Headlight Relays
Also be sure to check all your grounds and wire connections and use the correct wire gauges.
Next is to use a good set of H4 bulbs and lens.
Hella headlamp H4 H1 Conversion Headlights 7" 5 3/4" Hella High Low Hella European Halogen
That should brighten things up.
If you post where you are located you may also find a local owner that may be ablt to assist you too.
Wayne
Take a look at these guys - xenonpro.com. I got one of their kits a few months ago, much brighter and the install was pretty straightforward.
Watch out for the kits on ebay etc. - been there, done that, terrible. Or if you're not sure, your garage will be able to recommend a good kit for your needs.
