1 - 12 of 12 Posts
First is our top of the line:
DIE-CAST OEM REPLACEMENT HEADLIGHT
> Glass Lens
> Multi-Surface Reflector
> Die-Cast Aluminum Housing
These sealed beam housings are designed to not only give your vehicle an updated look but 30% more light output with their Multi-Surface Reflector Technology. No modifications are necessary, just plug-and-play. Add our superwhite series halogen insert bulbs and get over 60% additional light output over your factory housings.
These come empty [no bulbs] for $140.00 regular. I have 1 set on the shelf & 5 coming in Mike says we can sell for $115.00 a pair with bulbs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
Discussion Starter · #2 · (Edited)
Tri bar styles!!!!!!!!!!!!!!!!!!
We have 2!
The first is blue dot with turn signal tri bar setups [yes they are made in China] These also have bulbs & are $75.00 a pair! These are plastic housing & lens
The second is clear dot without turn signal [also made in China] These come with bulbs & are also $75.00 a pair!!! These are plastic housing & lens
Still available?
*PM sent*
Do these come as Tri-Bar lights with black center option? Thanks, John
> Glass Lens
1 - 12 of 12 Posts
