need help. couldnt get headlights to work got the turn signal stalk and plugged in hi low harness connection and everything works fine. how do i connect from harness to dash toggle switch and bypass the turn signal stalk. the plug on the harness has four wires (2 hot). searched archives but couldnt find anything on point thanks jb
I assume that the dash toggle you are referring to is going to be your high/low dimmer switch? Wire the R/Y to the center post of your toggle. LG/BK to one post. R/BK to the remaining terminal on the toggle. DB/O power wire is for the flash to pass feature. Colors are '89 harness.
Over Engineerer
If you want to keep the flash-to-pass circuit you can do it like this. If you don't then follow Pauls instructions - it's much easier.
