Hey guys haven't been able to find much info on this one.
How exactly is this S spring/clip installed into the headlight? I've given it a once over a couple of times and can't seem to figure it out.
Running JW Speaker headlights.
Thanks!
358834
It's purpose is to tension the trim ring. Really doesn't have anything to do with the headlight itself. There's a picture in the build manual of where it goes on the front of the headlight bucket. Text: "Push the spring clip onto the boss near the bottom of the bucket. The trim ring hooks over the bucket on the top and gets a screw it in the bottom using the oval head screw." When you hook the trim ring on the top if the bucket and push into place around the headlight, the ring snaps over the spring clip.
Discussion Starter #3
Well, this was so simple I feel a bit embarrassed!
For anyone else that may miss the obvious, there is a slot specifically for this clip. Pictured below.
Thanks Edward!
358840
Don't feel bad. I put it in as per the instructions and was wondering "what the heck is this for and will it stay in there?" Once I put on the trim ring...."ahhh got it".
