1 - 11 of 11 Posts
Baghdad Bob
I have found that there is supposed to be a spring clip. according to build manual ver 3A. My headlight trim rims havent fallen off yet but they are alwaysloose it seems the spring clips would make them more secure.
Does anyone know if I am correct and where that small part coule be obtained?
The supplied spring clips are not up to the task. Simply make your own. This is a common problem. A search of past posts should bring up a few "How To" Pics/Videos.
Krusty
Baghdad Bob
I appreciate the feedback i am not exactly sure what the clips look like but am willing to fabricate my own if i can figure that out. The build manual shows a "clip" being installed. But its not too clear.
Actual builder now!
They are just flat little preces of metal that screw in and hold the light. I too had the same issue with them being loose. Found I just needed to bend them a little so they applied pressure when screwed in
That's what holds the headlight in the bucket, He's talking about the spring clip that helps hold the outer trim ring. Two different things. The spring clip is sorta 'S' shaped, one end slides into the headlight buck. I don't know where you can find one though.
This is the piece.
Rectangle Tints and shades Liquid Metal Fashion accessory
The flat side presses onto the bucket at about the 4 o’clock position. They are primarily an anti-rattle clip; the ring is actually held by the screw that goes through the ring and into the bucket at 6 o’clock. Like Rich, I don’t know where you’d find them individually.
Baghdad Bob
Thanks Jeff and Rich
I have scoured thru parts web sites like the Moss Mptors one who sells lucas and MG and other such parts, scoured my gacage for millions of leftoverparts as well.
Baghdad Bob
at least now I know what I'm looking for, gonna call Mark at Breeze and also Factory five as well. I ws thinking i may try and fabricate somethinng from aluminum or spring teel.
Baghdad Bob
Discussion Starter · #10 ·
Thanks for the link. I will order some and see if they work. Will let u know.
Actual builder now!
Ooops. My mistake.
1 - 11 of 11 Posts
