1 - 2 of 2 Posts
Mike when ceramic coating your headers have there been any problems with the pieces that bolt up directly to the heads?possibly affecting the sealing ability? Thanks Fred Carnes
As long as the coating is even and smooth there should not be a problem. I would take a sanding block with a med grit paper and sand the flanges flat before I installed them and I would also put a thin coat of anti seeze on the gaskets to keep them from sticking if you need to remove them. also don't foget to use the lock washers under the header bolts to keep them from bottoming out on the flange plate.and re torgue the bolts after a couple of heat up and cool down cycles. ;)
1 - 2 of 2 Posts
