1 - 15 of 15 Posts
Any body out there in the tool world make a box end wrench specifically for 7/16 header bolts? I just ground down and narrowed an old wrench. But it really needed no offset to function perfectly.
But does Snap-on, MAC, Sears etc make one?
[ November 28, 2004, 04:48 PM: Message edited by: mikiec ]
The Traveler
I gave up and installed stage 8 bolts! Now I can use a wrench or an allen wrench! Works much better!
mikiec
Some specialty tools are regular tools bent or ground down. Take the box end and grind it down to make it thinner...
Any good hardware store should have grade 8 hex head allen bolts for pennies. Grade 8 will hold the headers just fine...
Stage8 - :D
ARP NASCAR spec 12 point header bolts. Safety wired, and will never come out. Also gives the proper amount of "bling"
We don't need no stinkin stitches
Fine bling there. That looks kick a$$. I love it.
Im never gonna finish this car :D
My trouble with the 4into4 headers is I can't get a socket on the bolts! With the bolts supplied by FFR, there isn't any room and I have to use an open end wrench to tighten them. Are the 12 point bolt heads smaller?
Ray
Discussion Starter · #11 ·
Ray,
I had to change out the gasket, leaking. That was my problem. My ground down wrench did the trick.
The 12 point bolts are 3/8", and require a 12 point box end or line wrench. I use a cut down box end. The headers in the photo above are 1 3/4" and they can be a chore to install.
Snap-On 7/16 angle open end wrench. I don't think anyone else makes one, so be ready with $20 or so. Fit's right in, and the quality of the steel let's you really bear down if necessary.
Marc A
I use a "crows foot" wrench which goes on the end of a 3/8" extension. It was the ONLY way i could get to some of the bolts on my 4n4's. It is also the only thing I've ever used the "crows foot" wrench for in the 15 years I've owned it, glad I never through them out!
1 - 15 of 15 Posts
